Recaro driver seat
  • Recaro driver seat
    I found used Recaro Style seat from ebay. Recaro don´t manufacture seat consoles for Land Cruiser J9, so I ordered König seat console and rails. I don´t know if König seats are much lower and wider, but the console was too high and too much left. I had to cut it peaces and weld it back 4.5 cm lower and 3 cm more right. Some other modifications was needed too. Overall, I like the result.
    The handbrake was not a problem:
    [size=1]
    2007 FJ Cruiser 6M/T[/size]
    Re: Recaro driver seat
    Originally posted by Trojan
    Originally posted by KZJ90
    and too much left.
    You're not kidding, it's so far left it's on the wrong side.
    :lol: Wrong side, ha ha. Only postmans drive RHD cars...
    [size=1]
      Looks good but the concern to me is the length of the front bolt in the seat frame, this has no vertical strength and could be an issue in an accident I would have thought.
        It does look long. If it's the same as the normal recaro baseframes, they use internally threaded rod to make the frame sidebars, so what you are probably looking at is the rod, not the bolt itself. Really should have an engineer check over the mounting in any case.
        Michael
          Michael
          That´s right, just like you told.
          The console is tested in test laboratory and I have a document of it too, but the structure is not too strong. I made couple reinforcement to it, for example that triangular part behind front mounting point.
          [size=1]
