Do you know that Toyota do a replacement boot, that you can fit without removing anything, not too sure how it works or actually seen it, but have heard good stories about it.
CV boot replacement
If you remove the CV when changing it make sure you replace the seal thats at the end of the diff housing, these tend to suffer damage when you remove the cv, its sort of their expiration. Do this along with greasing generously the cv under the boots and changing diff oils so youll kill three birds with one stone (although its technically only one bird) but itll save you future headaches.
Cheers.
