Preference, locker front or rear ?
    You're Welcome!
    Micheal.
      Originally posted by 120D4D View Post
      You're Welcome!
      I thought you would like that pic, I would have used this one but I have 2 lockers so it didn't really highlight the point
      We have to go back one day so you can get a proper shot of yours there Michael
        locker
        Rear locker, as AJ 120 says the front wheels cant spin with the centre diff locked
          Great info Andrew. This is also my understanding with centre diff locked (which it always is when heading for the serious stuff in the Prado, HL/LL). Been reading a bit on the Lokka, and the reports and reviews are very good and appear to be at least half the price of an installed E Locker or Air Leaker.........errr, Locker.
          Baders-1996 Prado 90 Series 3.4L/TRD Supercharger/2.2" Pulley/Xede ECU/Aquamist Water Meth Injection/Pacemaker Extractors/2.5" Custom Exhaust/West Coast Suspensions HD 50mm lift/Detroit Tru Trac rear diff.
            Thanks for the feedback Andrew, I will do the suspension upgrade methinks BEFORE the locker as this will allow me to get to know "The Pearl" and just what she can do!! before I take the step to the locker "upgrade".
            Larry D
            Ymus
            Also I understand because it is a Grande with the height adjuster etc that a 2"lift is not so much of an advantage... is this true, as I intend to reset the front end with springs and shocks and do the pin alteration for the Bags on the rear?
            "[B]The PEARL[/B]" is our early 2009 120 "Pearl White"Grande . [B]The build consists of[/B]: ARB deluxe Bar, Winch is a Domin8tor, Driving lights are 3X Korr LED's. Roof Rack is a RR 42107B. - Rear Draws are from OffRoad Systems 3 draw plus fridge slide, table and 40ltr S.S. tank. See our build site : [URL]http://www.pradopoint.com/showthread.php?32140-Start-of-quot-The-Pearl-quot-transformation-April-2014[/URL]
              The wonders of the Grande suspension are a bit above me, there are a number of threads on Grande suspension and what guys do. Probably best to ask those questions in the appropriate thread and the Grande Guru's will set you straight.
                I recommend rear locker, because it adds to the strength of the solid rear axle. It can be used for entire climbs without being concerned about CV failures or steering.
                A front locker will give you the most traction for your dollar (given you'll still have a rear LSD), but at the risk of CV failure and irregular steering.
                It may also depend on what terrain you drive, and in your case, I'd still say rear.
                Since I have both, I use rear most times, and add the front only in extreme situations (typically big rock steps).
                  Originally posted by baders View Post
                  You might have to explain that a bit more Scott........TRD ? TRC ?
                  Typo.... Meant to be TRC...
                    Your dead right Andrew there are heaps of threads and I will start to focus up on them. Its important to me to get the right advice re the suspension - so many variations and opinions?
                    talk soon
                    Larry D
                    YMUS
                      Well, I called 4WD Systems and apparently the Lokka is "not compatible" with the 90 series V6 manual. They were the only two words I could get out of the fellow
                      Don't think I can justify over $2000 installed for a rear E Locker either.
                        Only other thing I 'd be considering is how much longer do you intend to keep the vehicle? Worth throwing that locker into a 120 or even 150?
                        1996 3.4L GXL Manual in Crystal Pearl - [B]SOLD[/B]
                        2014 D4D VX in Silver Pearl with: 265/65/18 BFG KO2's, Safari snorkel, ARB Summit & Kaymar barwork, ARB UVP, Roadsafe recovery points, Superior Engineering 2in lift, OL diff breathers, ICOM IC-450, Redarc Dual Battery, RhinoRack Backbone, MaxTrax and more to come...
                          Same price over here in Sydney baders, give or take a hundred either way.... I'd go rear first as in my opinion the rear LSD in a Toyota is near to useless from the factory. There normally totally screwed by 40 thou and ready to be shimmed up again. ..... Cheers Steve
                          • #28
                            I would ring them back and ask to speak to someone else ,,, The 90 and 120 use the same rear diff...
                            • #29
                              I gather that the auto lokka's aren't compatible with manual gearboxes for some reason. Pretty sure it's been discussed in other threads.
                              AJ120
                              Out of control poster!
                              • #30
                                I gather that the auto lokka's aren't compatible with anal gearboxes for some reason. Pretty sure it's been discussed in other threads.
                                Is that when the gearbox is in the back end, like a 928 Porsche?
