Prop shaft, what grease?
  • Prop shaft, what grease?
    Hey guys,
    as above, what grease should I use to lubricate the prop shaft?
    Cheers.
    2000 Prado Kimberly GXL VZJ95R 3.4L V6
    Re: Prop shaft, what grease?
    HI Fredom 010 I get the guy where I get my wheel aliment done every 10k to squirt a bit of grease in while it,s on the hoist high presure high heat rating is the go I use Castrol APX T in my gun.CHEERS TINKERA.PS don,t go crazy with it or you,ll turn it into grinding paste.
    2004 DuneGLX UPDATE V6 FACTORY BULLBAR IN CABIN DUAL BATTERY SYSTEM ECLIPSE SAT NAV.REV CAM.DVD. CD.IPOD COMBO. COOPER HT TYRES.6DB MOBILE AERIAL HIGH GAIN FM AM AERIAL.ALL TOYOTA OPPS.JOEY REAR DOOR TABLE DIY SIDE SHADE.55LT FRIDGE FREEZER.300WATT INVERTER.
      Lithium base NLGI in both the slip joint and universals.
      Mick
