just under the car today checking up on things and noticed there seems to be a lot of free play between the inner joint(tripod joint housing) and the diff housing, with out measuring it seems to be about 3-5mm. wandering if this is normal or excessive? doesn't seem to be much written about this in the manual? Thanks
90 series front axle
Re: 90 series front axle
In the CV joint or in the diff?
Backlash of this amount in the diff can be considered normal.
