Hella 4000 compacts
  • Hella 4000 compacts
    Hi all
    I'm looking at getting a new set of spotties as my 240 blitz are kinda crap and a little too big. I was looking at hella 4000 compacts but have heard from a few peole that there not too good anyone have any experiances with these lights. I was looking to put a hid conversion into them at a later date anyway. Also with my blitz's i have one of those combo lens on it but find it doesnt do to much and i would rather see a coupla hundred meters in front rather then 3 million kays down the road so i was looking at getting the hellas as both driving/spead anyone tried this before.
    Firey,
    I haven't used the Hella 400 compacts myself as I have IPF 900XS's.
    These come standard as a Spot & Spread combo which is adequate at best with the standard 65 watt halogen but does have a good spread pattern and spot beam.
    I converted these to 55 wat HID with great results, the spot in fact became imo obsolete as the range of the spread increased so much, so I then replaced the Spot lense with a Spread beam lense. This works very well with the 55 watt HID as the range is well over 500m (reflects off road signs past a 1000m) but with a very wide spread
    Traditionally Hella have a very good beam pattern so if you are going to "upgrade" to 55 watt HID I would fit 2 spread beams unless you have a specific need to see a long long way down a straight section of road.
    Lee
      G'day Lee
      Thanks for your reply. With the 55w hid are they alright or would you upgrade to the 70w as there about the same price
        Firey,
        I am happy with the 55 watt, as for the 70 watt, I would see what size the ballasts are etc, plus some of the 70 watt lights don't seem have much more output in comparision. I have read that some of the higher wattage HID kits are not the real deal so would shop carefully.
        Lee
