2000 model headlight adjustment
  • 2000 model headlight adjustment
    Hi all, I did a google search and only came up with 120 series adjustment. Are the 90/95 series headlights adjustable up and down?. I did the Phillips Extreme 100+ upgrade and I'm worried now it might be a bit bright for the oncoming vehicles.I thought if I could angle them down slightly would be better. I had a look and cant see anything obvious. Any help appreciated
    Thanks Steve
    Steve
    2000 Grande
    Toyota Alloy Bar, IPF 900XS, 50 mm Lovell Springs in rear, Safari Snorkel, Kaiser Roofrack, Milford Cargo Barrier, Hercules AT's, Blue tongue compressor, Uniden UHF, Dual Batteries, Home made rear drawers, 45l Waeco with Waeco temp monitor, Side & rear awnings
    Thanks Steve
    All headlights are adjustable, up/down and left/right
      Thanks Croozza I thought so, but I cant see the adjuster, any idea where to find it please.
      Thanks Steve
      Steve
      2000 Grande
        I have heard of the adjusting screws falling out of headlights from different brands, but have never heard of it happen with a Prado. can you place a pic up so that we can see
          Thanks Croozza I'll try and get a pic tomorrow as lol my camera doesn't take very good pics in the dark.
          Thanks Steve
          Steve
          2000 Grande
            To adjust the aim of your head lights on a 90 there are two screws between the head light and the front cross member just behind the head light (on the left and right side of the light). One is for adjusting up down, the other for left right.
            Mint 1999 GXL Prado - Work in progress
              Look for the screws that "seem loose". Theres a screw on each headlight right next to the grill that seems to be loose because it sits high. That's the beam height adjustment screw..
                Found it and adjusted them. Thanks Croozza, Darren and lugueto for your help I much appreciated it
                I thought they were it but they looked loose and like it wouldn't do anything, anyway thanks again all fixed
                Cheers Steve
                Steve
                2000 Grande
