Cruise control not working
  • Cruise control not working
    My 3.4L Manual has a problem with the cruise control.
    The unit turns on fine but when i go to set the speed, it doesn't engage.
    I believe that there are a number of sensors to disengage the system such as the clutch and brake pedals although haven't managed to locate the sensors.
    I was wondering if anyone has had this problem or if anyone has a solution?
    cheers
    DAN
    [b]White '02 VX Petrol[/b]
    [color=#4000BF]Mods:[/color] Kicker amp and Sub, IPF 800 spotties
    [color=#FF0000]Wish list:[/color] Poly Air suspension, Pirrelli Scorpion tyres
    Re: Cruise control not working
    Hi Dan,
    Check the contacts in the switch itself. I have had an issue similar in a previous car. You'll have to remove the steering column cover to get at the contacts.
    Hope this helps.
    BirdMan
    David
    2013 FJ Cruiser
    265/75r17 Cooper ST Maxx, Rear locker/A-Trac/Crawl
    Losi Comp Crawler for the really rough stuff
      cheers
      DAN
      Hey Dan,
      Just wondering if you got this sorted?
      My uncle has a 90 gxl and it has the same issue.
      Can you pm me what you did to rectify?
      Wes
        a blown tail light or a switchover to led tail lights will cause the cruise not to engage
          He hasn't changed his lights to led.
          All the brake lights are operational
          He hasn't done anything to the car except put lpg on it 4 years ago
          cruise light illuminates on dash but cruise wont engage at any speed
          Wes
            Mine used to pop out of cruse when I hit a bump, if I pulled the brake pedal towards me it would stop this happening. One sensor must be on the brake light switch, not sure where the clutch one is but I'd put money on this being your fault if the brake light is working as intended.
            2[FONT=Arial Narrow]008 Prado GXL D4D Auto with Prado Pack
            4x4 History: 2000 Prado GXL 90 Series 1KZ-TE, 1992 4runner 2.8 Motson turbo, 1985 Landcruiser 60 Series 3.9L Diesel, 1985 4Runner 2L 2.4 Diesel later mod. + 2.4T (Factory Turbo), 1982 Hilux 2.2L Diesel in Yellow (callsign 'Yellow Peril') later mod. + 2.4L engine[/FONT]
              there should be a switch on the clutch pedal itself. Similar setup to the brake switch. Common fault.
                Also was told it was caused by low fluid level in brake cylinder.
                Michael and Kelly
