I purchased a S/H Prado VX Grande 99 model nearly a year ago. ( very happy with it both on and off road) For some bizarre reason it doesn’t have keyless entry even though this is apparently standard for the Grande model.
Anyway after getting the Gregory’s handbook (according to this I am an early model wiring system of the Prado 90 series) and a bit of sleuthing around under the dash I have found the following.
On the left hand side of the car under the glove box and fan unit, behind the kick panel near ones left foot when sitting in the passenger seat, there should be a remote receiver module. (For those who have cruise control this is where that is too.) I think I have located the plug for the unit and I just want to confirm what others have so I can then…
A) Go and buy a Remote Receiver Module from Toyota or
B) Maybe someone knows of where I can get a second hand part.
The pin out when looking at the socket end is as I have, is below for my vehicle.
2 rows with of 7 pin outs
top row I have numbered 1 to 7, left to right
bottom row I have numbered 8 to 14, left to right (10 and 11 were not used)
1 Yellow
2 Red green
3 Blue White
4 Blue Yellow
5 Green Yellow
6 White Black
7 White
8 Green Black
9 White
10 Not used
11 Not used
12 Blue
13 Black Red
14 White Red
I have found that this socket…
White Black is ground (6)
White Red is +12v supply through ECU-B fuse (14)
Blue White is the lock side of the door switch (3)
Blue Yellow is the unlock side of the door switch (4)
(I would like to provide a picture in this post as it wold be so much easier.. Hmm how does one do that in this forum?)
So if you have something similar, part numbers of the remote receiver module you have, would be just great.
Thanks in advance
1 Yellow
2 Red green
3 Blue White
4 Blue Yellow
5 Green Yellow
6 White Black
7 White
8 Green Black
9 White
10 Not used
11 Not used
12 Blue
13 Black Red
14 White Red
Thanks in advance
