Symptom: With the Fuel tank full and the Caravan connected and Fridge Running on 12V the fuel gauge only reads 9/10 full.
Problem: It appears when the Anderson Plug and the 7 Pin connector Wired the Earth (White) wire was connected to a Bolt on the L/H rear of the Chassis. It appears the connection between Motor and Chassis is only a thin wire (Somewhere ?) on inspection connection to Body can be seen however to the chassis ?? and appears to cause a drop of potential and the fuel gauge reads low.
Fix: I connected a 10mm Sq wire between the Battery and the Chassis picking a threaded hole on Chassis directly below the battery.
and later extended the wire to both Connectors as I also believe it is not wise to use Chassis as earth return.
This resolved the low reading Fuel Gauge hope this may help other folk with the same symptoms.
