Hi fellas, signed up to this forum the other day as it's a great resource! I presently own the 3rd gen Hilux Surf (KZN185) with the 1KZTE. Since these share the same engine a chassis as the prado, much of the info on here is applicable to be also. Reason for my post is that I needing a few pictures of the intercooler on a drive by cable 1KZTE 90 series. In particular, some shots from the manifold side, showing the throttle cable and kick-down cable setup, and the brackets of the intercooler and how it's mounted. I've managed to pick up an intercooler from a drive by cable prado (as my surf is one of the first 185's it is also drive by cable - the KZN185's moved to drive by wire, similar to the prados, a year or so later). It should be a straight forward fit up, but pictures will help to see if I have all the bits ready to go.
1KZTE Intercooler pictures needed
| LSD | OME 2" Lift | Cooling Mods | DP-CHIP | 3" Zaust | Alpine Sound | Tint | T-Bar | Boost Controller | EGT Guage | Auto | Dual Batteries | Dicki Seat | OEM Intercooler | CB-Radio | Cruise Control | Whispbar HD Roof Racks | Prado TJM Bullbar | Great Whites LED |Tags: None
Great! That would be fantastic. I'll message you my email[B]KZN185 SSR-X 1KZ-TE[/B]
