Hi All
I have a 02 turbo diesel 90 series which only has 147000ks on the clock Its a guzzler i change all filters every 5000k or 6mnths serviced injectors at 100,000 i have installed a rapid diesel chip but it was sucking fuel before that im lucky to get 800 to 900 ks out of both tanks it doesnt blow smoke only if i engage the chip which i can switch on or off. When 1st purchased new on 02 was getting around 1600 to both tanks i did notice a small difference when i fitted a snorkel.
It has done many trips simpson desert arnheim land frazer etc i know tow a small caravan 7 consumption is the same towing or not
is any1 out there have the same problem or any idea of a fix
cheers John
cheers John
