1KZ 3.0 Rebuilt
  • 1KZ 3.0 Rebuilt
    hi guys
    my engine will die at some point and i'm thinking of rebuilting it or replacing it. it seems to be a compression issue so might need new pistons or not
    as i live in Cyprus and the parts are very expensive i was thinking if someone can make me a list of parts that most likely i will need and how much they cost in Australia? i have some relatives in Sydney so propably they will be able to send them to me
    thank you
    Re: 1KZ 3.0 Rebuilt
    In Australia the cheapest option is to replace the engine with a Japanese low kilometre import engine, these can be had for between $2000-4000 Aus, but you usually get everything... turbo, alt, starter, pump etc.
    A new long motor from Toyota is around $9000 Aus (block and head, no accessories but brand new)
    Not sure on the price of a rebuild kit from Toyota Australia.
    A good option for you may be to get the parts out of England, there is often a seller on EBay doing 1kz rebuild kits at very good prices.
    Try contacting this seller as it may be them:
    Ebay link
    Mick
      Re: 1KZ 3.0 Rebuilt
      cheersMick, i will give it a try. in cyprus i found a used engine @ 2500euros but have no idea what sort of miliage it has on the clock
        Re: 1KZ 3.0 Rebuilt
        Try this guy if you can't get anything in Europe... Price is pretty good, you'll just have to check on freight cost;
        1kz rebuild kit
        Mick
