Starting to blow some smoke, slight power loss and use a bit more fuel than before esp when towing under load in my 2001 TD Prado manual, as the injectors and fuel pump have not been serviced at all over the 220,000 km starting to think that they might need servicing, tried the injector cleaning additive, it improves it but only if i put 150-200 ml in each tank, then once it is used up it goes back
Heard some good reports about West End Diesel at Wetherill Park, does any body have any good/bad experiences with them, or alternatively can reccomend someone closer to home (Castle Hill)
Regards
Gerry
Regards
Gerry
