i have a miss when hot 3.4 lt
  • i have a miss when hot 3.4 lt
    i have had power problems with our 2000 3.4 prado has a miss when it is hot but only when you stop it after a small drive and start it up after 5 min it misses have replaced plugs, leads, coil packs, injectors cleaned any ideas people please and done a compression check too all good at 200psi
    Sorry, never had a problem like this.
    Michael and Kelly
      need more detail
      although im not familiar with this issue, however, i think if you try to describe more details of the issue, it may be helpful for others to recognize the error for you.
      - how did it miss? do you mean you can not crank the engine?
      - what did you hear when you try to start the engine at the time it is hot?
      - did you try to open the bonet first, then try to start the engine, then you should hear any noise when you crank the engine.
      - how long do you have to wait until the car is cool down enough to get it start?
      - did it happen if you run the car for more than 5 mins (ex: half an hour or an hour) and then try to start again within 5 mins?
      hope that you will get it fix soon
      [b]1997 RV6 3.4L Petrol, manual.[/b]
      [b]FUEL: 15L/100km[/b]
      [b]- Mods done:[/b] TJM roofrack/2nd battery/Power windows-mirrors/LED mirrors-signals-Eagle eyes-Angel eyes-all around/2x12.3" sunvisor LCD/Automatic roll up-down windows/Chrome cover all around/6.1" Kenwood DVD w 180Gb HDD/4 amplifiers/4x12" subwoofers/Air compressor/Weaco CF-32/4 oval x HID front light/Hot shower/Water pump/Bike rack
      [b]- Waiting list:[/b] vertical Lamborghini door/UHF/2x9"DVD headrest/Pioneer components/19" DVD roof flip down/12k lbs winch/XXX...
        Have you pulled up any error codes?
        I say either Air flow meter or Cam sensor.
          no codes at all used a scan tool
          and thats what i was thinking well trying to get a air flow meter to test it on the car next
            have you tried replacing the fuel fliters? also follow fuels lines into the engine. look for fuel lines that could be getting hot when the car is sitting still - you might have a vapour lock problem - a hose may have come off a clamp and be resting against something hot.
            2001 VX 3.4, Dual Fuel, TJM Nudge, IPF Spots, Uniden UHF, Ming Tint, Dust deflector, side steps, Bridgestone D694LTs. [url=http://www.fuelly.com/driver/Westy90/prado][img]http://www.fuelly.com/smallsig-metric/68370.png[/img][/url]
            [url=http://www.postimage.org/][img]http://s1.postimage.org/gu8j7rlw/prado_avatar.jpg[/img][/url][url=http://www.postimage.org/][img]http://s1.postimage.org/guigfukk/08062010_001.jpg[/img][/url]
              fuel filter has been done and all the pipes are in their clips
              and when it does miss it is all the time
              matttassie
              Lurker
                all fixed now it was a bad injector the ohm reading was hi at 27 ohm they are ment be 13.4-14.2 ohm
