I seem to be developing clicky disease, every few times I go to start it all I hear is a click and she won't turn over, have already removed and cleaned the contacts on the inhibitor switch, is there any common problems for these I need to know?
Starting problems
Sounds like the alternator (I think) is packing it in. This happened in my 90 and after the whacks with a hammer stopped fixing it they replaced with a reconditioned one.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
It's probably the starter solenoid.
If you remove the starter motor (hard job), there's a test you can do to determine if it's the motor or solenoid. It's described in the Haynes workshop manual.
Cleaning or replacing the solenoid components can resolve the issue for a while, until you punish it with more deep crossings and mud.
EDIT: Check this thread:
http://www.pradopoint.com/showthread...-Starter-motorglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
