the plastic cap has gone missing off my dash pot - does any one know what the dash pot does and loosing the dust cap cause any problems in the future if not replaced ? the local dealer ship had know idea
Dash pot
What do you mean dash pod, are you meaning the instument cluster?? or the one that sits in the centre on top of the dashboard, which was not part of the OZ spec???
Could you give more info please97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
If its what I'm thinking of, the dash pot slows the closing of the throttle for anti pollution reasons.
So if you open the throttle butterfly and then let it go, it should snap back except for the last 10 degrees
or so which will close slowly.
At least that's what used to happen on carby models.
LeighHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
