ive had my very first major drama with my prado... only its a pretty bad one!. I found that my crank shaft pulley was "on the piss" causing loose belts etc . i pulled the fan out and all belts and got my crank shaft pulley off. what a mess!!! the shaft wasnt too bad, but i could still see that there has been a slight amount of pulley movement. but the key is almost completely flogged out! the harmonic balancer is flogged too. Things are looking quite expensive, especially if i gotta get some machining done.
Has anyone ever come across this before?
