Prado RV vibrates when eccelerating
  • Prado RV vibrates when eccelerating
    Could someone please help me???. My prado RV vibrates when eccelerating through each gear!!!.
    Auto or manual?
    Does it only occur during gear changes, or certain speeds, or constantly, or braking, cornering?
    Some simple things to check would be:
    -Tyre nuts and balance.
    -Engine mounts.
    -Transmission mounts.
    -Front CV joints.
    -Front & rear drive shafts.
      Hey mate,
      It's a manual and it usually happens after each gear change while eccelerating then goes away until i change to the next gear, the whole car inside vibrates,
      it's really anoying....
      Might take your advise and check the follow i'll get back to you, thanks mate....
      Josh
        Could be an output shaft bearing in the box.
          Hi Croozza, thanks i'll check that out, hopefully it's not what you say it is....
