Having a bit of trouble with my fuel flap opening. Will only open if I pull the release lever as normal, but then need to grab the actual cable behind with pliers and give it a little bit of an extra pull to actually open the flap.
So I'm guessing it works similar to a handbrake cable, so saying that, does anyone know if (and where) you can adjust the tension of the cable?
-Rob
-Rob
