Lwb 95 swb 90
  • Lwb 95 swb 90
    I need some clarification. Did the 90 series come out in different wheel bases? I have a 97 90 series and know the SWB was not released in Aus. What is the difference between a 90 and 95?
    95 is the short wheel base.
    90 is the long.
    More to come!
      Its the other way around
      90 is the SWB
      95 is the LWB
      KZJ90 1-KZTE GL
        So if I have a 1997 model, is it a 90 or 95?
          Exactly what Bounder said
          If it's a LWB it is a 95
          If it's a SWB it is a 90
          Have a look at your VIN number
            In Australia it would be the 90 series it was made from 1996 to 2000, the "name" 95 series began in the last couple of years that the 90 series were made. Basically all the prado's here were 4 door, not the 2 door version(is this what you mean by SWB).
            Ron.H.
            2001 3Lt Manual Diesel, Safari Snorkel, ARB Winch Bullbar, Hella Spotlights, 9000lb Warn Winch, Dual Battery, Couplertec Electronic Rust Prevention, Glind Hot Water Shower, ARB Front and Rear Air Lockers,Onboard Air Compressor, DP Chip, 40mm OME Lift, Steel Slider Side Steps, GME 3200 CB Radio, Milford Cargo Barrier, Extended Diff Breathers, Draw system and Fridge Slide, 40lt Engel Fridge, GPS with Wireless Reversing Camera, Rhino Roof Racks with Aluminium Tray, Awning and Drop down Table on Rear Door.
              to just answer the question for you in plain english:
              you have a 95 series.
              (like mentioned above check your vin it should say VZJ95**** or KZJ95*****)
              It confused me at first as well.
              99 RV6 Prado manual, 1" lift, ARB Steel winch bar, Ridge Ryder 9500lb winch, Lightforce 170 striker spot light, GME aerial,
              Uniden UHF, TJM full roof rack, custom diff breathers, Advanti 16" wheels, 275/70r16 Maxxis Bravo 751, Pioneer head unit,
              Milford cargo barrier, Tinted windows,
