hello. i've got a high pitched whirring noise that seems to be coming from around the front pasenger footwell area on my aytomatic. it does it in any gear and neutral, at idle and low speeds. above around 45kph and you can't hear it. i can't hear it if i lift the bonnet due to engine noise. can you help with any ideas as to what it may be? i've only had the vehicle 24hrs.
thanks.
thanks.
