Mad custom 90 series with 80 Series running gear.
  • #76
    heres the PTO that we got.
    was thinking about using a air ram instead of a shifter. what do people think?
    • #77
      Excellent thread! I would love to see a badass custom 90 series Prado.
      Check out this link. Itīs a Portuguese site but the photos and translator maybe help:
      http://forumflc.clubeflc.com/index.p...ic,1850.0.html
      Prado RZJ90. OME 881 coils Nitrocharger Sport shocks front, 80 Series front coils & rear 80 series Tokico shocks rear, 255/85R16 Cooper Discoverer ST, Viper rocksliders, parking brake cable rear axle bracket, extended rear brake line, extended diff breathers, headers, engine perfomance mods, soon LR upper control arms, ARB rear locker in the future.
      • #78
        Originally posted by Tones120 View Post
        its going to be a 3link kit up front. heres a link to the guys that make it
        http://www.trail-gear.com/trail-link-three
        we are going to try and run coilovers and triple bypass shock with hyro bump stops to stop up travel and to take the harsh hits out as well and some kind of torsion sway bar to keep it flat when going around corners hard this kind of fornt end will flex way better.
        No kidding. That kit uses some seriously long links. Should flex nicely.
        Obviously as this is going to be a Frankenstein part-Prado, part-80 series, part buggy, it will be hard to compare to any stock vehicle, but how high do you plan on having it?
        • #79
          mate that prado is sweet. cant do read it but i can see all the work thats gone into it.
          • #80
            we are wanting it to not be lifted on the coilovers any more then 4incher but would love to get it down some where between 2 and 3incher as it will be running a 2inch body lift as well. the plan is to run 12inch coilover so and it would be good to get about 5inchs of up travel and 7inchs of down. but will have to see if that can be done. and my mate had a 5inch coils and 3inch body lift in the 80 and its just way to high. to run the big wheels we are just got to cut into the wheel arch like the arctic trucks and like the gards you can get for the nissan.
            • #81
              its amazing with some work you can get your COG down which helps with speed and corning and driving on bad side angles.
              • #82
                been looking at diff housing as we are looking at beefing it up before we get to into the build. heres the link to the housing that we are looking at.
                http://www.ruffstuffspecialties.com/catalog/TOY8.html
                dam hardcore diff.
                • #83
                  dam thats one hell of a beefed up diff housing. 9mm tub not much need to truss that. no bent diff after so air.
                  • #84
                    Well we just missed out on a $2000 90series that was licencesd but had a stuffed v6 but who care on plan in using it anyway. So now on the hut again for a cheap 90 with plates
                    • #85
                      What engine will you be using?
                      • #86
                        A mate got a 5.3 if we want to use it but we thinking more a long the line of a ls2 as they are cheap
                        • #87
                          If the 5.3 is free take it but is not go the ls2 it will only cost a couple of grand more but will be a hell of a lot more motor. 5.3 make about 340hp out of the box a ls2 makes 400hp. So if u pipe cam and tune then it's going to be close to that at the wheels. Power is king in sand and mud.
                          • #88
                            Will the 5.3 is going to be a wast of time. We may have found a cheap prado over east but we got to work out if trucking it over to the west is worth it. It's a stocky so will go over the pits nice and easy.
                            Been working out the best way to get all the gear over here that's need from the state.
                            Got a mate that well do the ute chop. He's done a heap of different chops so know what to do. He all so said the we may have to beef up the chassis as well so it doesn't snap in half. Which sounds like a great idea.
                            • #89
                              so whats going on with this set up?
