Hi guys, I'm new here but I drive a 96 Prado here in New Zealand. Recently we had to get the engine reconditioned after a blown head gasket from a burst coolant pipe. Then six months later the radiator started leaking, so we replaced that, then the thermostat stopped working so we replaced that too, we also had to replace the fan resistor as it only ran on full fan speed. Now when we turn the heater on in the car, the air coming out is only luke warm, even when the engine is at full temperature (just under half way on the dial) it never gets hot. Both the pipes going through the fire wall are warm and the fan in the heater is working, but I freeze on my way to and from work every day. My mechanic cannot figure out what it could be so I thought I would ask you kind folk for any ideas on where we could look for the fault.
Kev
Kev
