where is my sub tank guage
    That would be pretty pointless, then
    Just as pointless as having 2 tanks but no gauge for each tank.
    [B][URL="http://www.pradopoint.com/showthread.php?30380-Ratsack-s-90-Series-Prado"]Toyota Prado GXL Kimberly - 95 Series - 3.4L V6[/URL][/B]
    [QUOTE=maulbeagle;469810]Have heard that the fuel consumption of the petrol engine is horrendous ?[/QUOTE]
    [QUOTE=amts;469812]Heard that a replacement D4D engine is horrendous [/QUOTE]
      Hi guys
      I have finally gotten around to pulling the dash out and I have a 4 pin and a 8 pin so it looks like some one has just put in a clock
      does anyone have a duel gauge or can recommend a place to get one in adelaideClick image for larger version
      thanks for ur help
        Give these guys a call, they are dismantling a couple of 90 series at the moment. I've found them quite well priced in general. The part is small, so postage would be under $10 or so, so no real need to concentrate around Adelaide?
        http://www.wholesalecarparts.com.au/
          Stupid question maybe, but firstly do you have two filler holes when you open the fuel cap ?? Also have you stuck your head underneath to make sure there are two fuel tanks ?? Will be one write up the back under rear cargo area, the other will be on the passengers side running length ways. No gas (lpg) or the like under there ?? Not been the original owner some times you never know what the original owner has done. Also what model prado do you have ?? V6 RV GXL, etc 2.7 petrol ?? The 2.7 didn't come with duel tanks. Im sure the RV did and I know 100% the gxl, grande's and vx's did, Going by your stereo and the electric aerial switch you have a GXL which will have duel tanks.....Cheers Steve
            sub tank gauge
            Originally posted by bellebutton64 View Post
            Hi
            Can some one tell me where my subtank guage is
            I have a 2001prado 90 series and in my book it says it is when my clock is but there is no gauge
            I do have a subtank as i have the button for subtank but no idea how much fuel is in it
            HELP
            any one have a gauge for sale or know a good place to go in adelaide
            thanks for ur help
              hi guys
              have finally got time to pull the dash apart and i have a 4 pin and a 8 pin
              anyone have a gauge for sale or know a place in adelaide
              thanks for ur help
                Good point from Steve there... you sure it has both tanks?
