I recently had a radiator cap fail, a nice thing as it's easily fixed, but in doing so I discovered there's a model change
around the August 2000 build date.
I have now learned the radiator cap holds a higher pressure, 1.1 'metric bar things' instead of 0.9.
Fortunately I guessed right and got the correct cap.
Is this the change date between the 90 and 95 series?
Do you guys know of anything else of significance that changed then.
I have a GXL if that makes any difference.
