Recently got second hand genuine 3 spoke alloy wheels for 2002 TX which are to be fitted to a caravan being built for us.
Caravan manufacturer as asked me to supply wheel nuts to match the rim as per the following comment
"Now that we have the wheel rims we have made the adjustments to the suspension arms however we use a tapered 14mm wheel nut on our standard rims but the rims you have supplied wont accept a tapered nut and they are a flat nut. Can you supply 14 nuts to suit the rims so that I can get the chassis company to fit the correct wheel studs so that it will match up to the nuts to fit to the rim."
My online research indicates that the genuine wheel nuts are 21mm head, Flat base ( not tapered), 12 x 1.5mm.
Local Toyota parts wants $10 a piece and only has one anyway.
Can anyone suggest where I can get some wheel nuts from for this purpose.
