265/75/16 or 265/70/16
    Re: 265/75/16 or 265/70/16
    /hi, i had 265/75/16,s on my truck,i thought it was ok fuel consumpion/performance .then towed the caravan down south.at speed110/120kph got24to25 litres to 100ks not good,so fitted 265/70/16,s and a k&n air filter. did the same trip to wagga and the fuel dropped to 18 litres to 100k.s the smaller tyre diameter helps the gearing, pulls better ,the taller tyre seamed to kill the performance.cheers rossy
    99 snowy v6,bilsteins , pedders springs std height, polyair bags, bf goodrich at 265/70/16, daul batteries, safari snorkel, modified exhaust & extractors, rallie 4000s, gme tx472s uhf, 12v to rear ,40l ingel & slide ,tinted windows, rhino racks,electric brakes, trd supercharger,alpine cd & ipod, pp sticker.
    wishlist.rear drawers,,hid lights
      Mattman,
      If you get yourself a set of 16x7 GXL steel rims or a rim with the same offset you can fit the 265 70's or 75's without the need for flares, they look really good on the RV models to, sitting nice and flush with the guards.
      PradoPower has a set of Copper st 265/75's and GXL steelie's on his RV 6 and they look tops 8) .
      Edit : I just added a pic of the above mentioned Prado, as you can see the 265/75 Coopers sit just nicely inside the guards.
      Alan
      99 GXL V6, 2" EFS suspension lift, ARB winch bar, Mickey Thompson ATZ 4ribs, ARB on board compressor,front and rear airlockers, Hella 4000's, ARB ally roof rack, Ausguard cargo barrier, Safari snorkel, t max 9000lb winch, t max recovery kit,105 amp/hr Thumper dual battery system, Waeco CF50 dual zone,OZtent RV5, ERPS rust protection, PP stickers.
        Cheers pythonkeeper
        whats the go with fuel eco is it much worse or not to bad . Also do u know what year those steel rims came off and what offset they are ?
        P.S. thanks for your help everyone its good to get on a site that actually helps instead of just leaving the comment alone.
          Mattman,
          I think those rims should fit any year model 90 series, my GXL has the same rims and it's a 99 model, the RV6 pictured is a 99 model also.
          Fuel use does go up a bit with the heavier larger diameter tyres( as you would expect), but not by much.
            Polybags fitted!!! Prado now sits 1000mm at rear with 15psi Heading south for long weekend. Will let you know if fuel consumption has increased and if there is any noticeable power loss with the 265/75/16 D693's especially as we'll be towing the campervan.
            2002 GXL Petrol/Gas Auto, 70mm Lovell Lift, Blue Max Skocks, GME TX 3220, Lightforce 240 Blitz, Narva 150, Factory Bull Bar, Sony MP3 Stereo, 38 ltr Engel, Prodigy Electric Brakes, Polyair Air Bags, Bridgestone 265/75 D693. Rola Sports Bars, Large Rola Vortex Basket. Fire Extinguisher, Narva Work Lights Rear.
