Double standards?
The chassis was designed by our jap friends at Toyota to take either a steel or alloy Bullbar!!!!
It is also designed to take a winch up to 9509lb. Yes was!!!!!
The holes you use to bolt up your yellow lollipops, they were not designed for it at all!!!! But should be ok to rip the chassis off, if you pull str8 ahead. Side pull, well dampen that one well!!!!
I'm open to looking at any recovery points, I will consider anything, from all the information I have will access if I need them. At this stage, I am even more confident of he factory tow points than when this thread started.
At the same time, I'm less confident with the bolted on options. Especially 2 bolts each side, is an absolute no go for me!
Catch you all later
![](https://www.pradopoint.com.au/core/images/smilies/icon_wink.gif)
