Toyota Landcruiser Prado oil leak and coolant oxidation
  • Toyota Landcruiser Prado oil leak and coolant oxidation
    Hi. Can anyone tell what can be leaking in the upper control arm and also what can cause the oxidation around the coolant top? Thank you
    Grease from the UCA ball joint and small amount of coolant dried around the reservoir cap. Clean them off if your concerned
