The search funtion. I was trying to locate a thread by searching for the title and it wont search for words with only 3 letters, its a bit hard when you are looking for OME or OLD MAN EMU all of which have only 3 letters and the search function rejects them. Is it possible to change this?
I cant seem to get onto www.postimage.org which is where all my images are stored. Is anyone else having issues getting onto the site as it appears to be unavailable. http://www.websitedown.info/postimage.org tells me the site is up but I am unable to get to it....
What is the trick to using tapatalk (from iphone) with Pradopoint? I get:
'System Message
The usergroup you belong to does not have permission to login. Please contact your administrator.'
Guessing it is PEBKAC - problem exists between keyboard and chair.
Peter
Peter
150 GXL D4D Auto White
ARB Bull Bar, Toyota Tow Bar & Cargo Barrier, Anderson Plug, Prodigy, Window Tint, Icom 440 UHF, Snorkel (Toyota/Safari), Waeco CF50, Jayco Eagle Outback
Peter
I was using my iPhone to view some threads and saw some very helpful posts. So to do the right thing, I clicked on one of these posts to add to positive reputation points to the member. However, when I did so, it seems that it automatically added 'negative' reputation points. Normally, when you click on the reputation button (* type symbol), you get a choice to give positive or negative reputation points.
In this case, I neither got the choice and the system immediately just dished it out to the poor member who I was trying to help!
I have since sent a follow-up email to Admin hoping that this error might be reversed. A warning to other iPhone users, as this may be a system fault. When you thought you were giving positive reputation points, you may have been doing the opposite!
Unfortunately, I tried to undo the fault via my home computer, but cannot.
[B][SIZE=4]ntp
I am trying to make a purchase some extended swaybar links from the store "marketplace" but cannot get to the payment information page. The page is blank. This doesn't happen if I buy "merchandise" from the store. Any ideas?
Profile picture or Avatar Jasen? If it's your Avatar (the image below your username), then you need to add this in Settings\Edit Avatar and check the radio button that says "Use Custom Avatar" and select either opt 1 or 2. Remember there is a size limit of the image (80x80 or 19.5KB, whichever is smaller) You can compress or trim your selected image using a simple prog like ms office picture mgr. It's trail and error until you're happy with the pic.
Has this helped? or is there something more sinister going on?
When I type up a post and post it it doesn't appear the same in the post as it did in the editing screen
ie carriage returns have been inserted etc.
I re-load to edit and it looks as I originally typed it, I post again and same thing.
I reload to edit again and this time it looks the same as when posted ie carriage have been added ,
I re-edit and post and then it is ok?
Annoying, as it happens a lot.
Leigh
Its done it again, the carriage return after "screen" and "added" weren't in the editor window view?
Leigh
