spotlight lock nuts
  • spotlight lock nuts
    hey guys im sure this has been done before but a search didnt get me any results.
    im after some lock nuts for the spotlights on the truck just wondering if theres something out there to use, or what homemade ideas work.
    cheers Ben
    There's this
    http://cgi.ebay.com.au/ANTI-THEFT-LO...ht_2784wt_1139
      IPF made lock nuts which require a special adaptor to remove them and this comes as a kit.
        I've got the IPF lock nuts. Apparently there are a number of different fittings for unlocking. Each pair in a set uses the same but different sets use different ones but there are only so many combinations and they are numbered from memory with an alpha character followed by a two numerics to indicate what is what. You still need to use a spanner or socket onto the lock bolt. DOes the trick but if it slips then it can be painful. SO far after a few years and a LOT of corugations they havn't come loose but I do wonder about the ease of access or lack of as a simple lock.
        [COLOR=#000080]Nick[/COLOR]
          When I used to worry about these things I drilled a small hole in the shank and put small padlocks through.
          Cheers, Wayne
            There are all sorts of brands out there for lock nuts on your spotties. IPF, Narva, ect. I personally dont have them because the winch gets in the way of the spotlight nuts, they would need to remove the winch before they could get to the lights.
