Reverse Spot/Floodlight Ideas
  • Reverse Spot/Floodlight Ideas
    What ideas do people have or what have you done to fix an extra reverse light onto your car ie. Pole behind or on spare wheel holder or straight onto Roofrack/Cage? thanks Mass
    1999 Prado Snowy 265/75/16 Mickey T's ATZ 4RIB, Uniden 80 channel CB, 2" EFS with PolyAirs, PP Rear table, JVC Bluetooth deck.
    My preference is to have my work light mounted to my rear roof rack rail. It has the advantage of height for spread and is out of easy reach for the "silly-buggers". It is only wired as a work light. Im currently looking to replace it with an LED unit. When I can find an aluminium roof cage, at a resonable price, I will relocate my work light to the rear of the cage.
    Bazza.
      there is a thread goin on this in the 120s electrical section http://www.pradopoint.com/showthread...-LED-worklight. cheers samo
        Rhino-rack roofracks have the option of attaching light brackets. fairly cheap and as Bazza said, higher up helps to spread the light and the door can be open or closed without affecting anything.
          samo - you are sure all over it like a fat kid on a cupcake when it comes to posts that are already in a thread somewhere mick
          [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
          ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
            Cheers, I recon I will have a look into the LED Bars for sure.
