On the back of the GTG and realising how much stuff I took vs how much space I had to accomodate it I'm moving into Camper Trailer territory.
That said, I've just spent $800 on a Blackwolf Twin Turbo tent that has been used a grand total of once (or three times if you count the setup and packdowns of the GTG) so i'm not after the whole setup from day one until i get a bit more value out of the tent, just going for the space to start with and will build it up with time, but if there's something that has structural impact on the trailer then i've added it to start with.
So far, i've got a 7x4 semi offroad setup with 2x Jerry Can, 1 x 4.5Kg Gas, side opening tailgate, extended drawbar, vertical spare wheel, toolbox, stabiliser legs, full length side steps and a tonnaue cover.
There are two options i'm undecided on.
Mechanical override brakes for $700 (or electrical for $800)
Trigg polyblock Hitch for $340 or Hyland Hitch for $410
My question to you seasoned trailer/camper trailer draggers.... considering it won't have a tent on it at this stage, the trailer weighs in at around 350kg unloaded. strap in my gear, and some water and gas i would probably be heading towards 600kg... so i don't think weight is an issue.. yet.. quote is $700 to do it now or $1000-1200 to add it later. (i.e. in a few years when i get the tent added). at what point do i want brakes? make things easier in sand/soft dirt etc? stop trailer misbehaving under heavy braking? and would you go mechanical or electrical? seems like plenty of people in both camps!
Second Questions is the hitch, it comes with a quick release by default. i've seen a fair few "it's fine for most things" comments in other forums and i don't anticipate dragging it to the cape next week. Considering the places i would take it i.e. in and out of cruiser park, to and from the SA 2012 GTG etc... do i need to add a hard core hitch from the outset? What sort of angles do you get out of standard before you would want the 360 degree flex, what are the pro's and cons and those of you that have something other than standard, did you add it at the outset or upgrade later? Trailer guy is suggesting that it's a major job to change it over as they need to cut the old one off and weld on new plates for the difference. i've seen a few places that sell them separately so i'm not convinced it's such a hassle if i want to add later..
I'm not overly keen on the idea of having to undo the trailer ball to change trailer (i have a normal trailer as well, which is unappealing side of the Trigg hitch, the hyland looks good with a normalish connection.. but could be overkill....
appreciate your input!
