Pradopoint sticker - yes, I am inept
  • Pradopoint sticker - yes, I am inept
    Before I destroy my second PP sticker, can anyone advise me how to successfully get the sticker off the backing?
    Paul
    [SIZE=2]2007 GXL V6 manual + a few goodies
    [/SIZE]
    Peel it off.
      Paul
      Hi Paul,
      Try these instructions. But don't worry about the Hinge Method unless the backing strip is in two pieces.
      Cheers REV
      (Thanks Richo!)
        "Peel it off" Yes, Andrew, that is how I destroyed the first one!
        The backing is not coming away cleanly and parts of the sticker are peeling off the application tape and staying on the backing.
        I suspect that my batch may not have been so good, but I will give it another whirl.
        Thanks for the details instructions, REV!
        Paul
        [/SIZE]
          I destroyed one of mine- lucky I ordered two!
          Cheers, Brad
          2007 GXL, Dune, D4D 6 speed manual. Satnav, towbar, Sahara Bullbar, Bridgestone D697's, Cargo Barrier, Stebel Truck Horn, Couplertec Rust Protection, Safari Snorkel, Polyair airbags, Blue Narva 175's, VMS Touring 700HDsII, GME TX3340, Tough Dog 2" lift with adjustable shocks, ARB rear air locker.
            Originally posted by REV View Post
            Hi Paul,
            Cheers REV
            (Thanks Richo!)
            Hi Rev
            You hoarder you keeping the instructions, I kept them as I use them for all die cut stickers, can't wait to get my 2012 GTG sticker now
            See ya on the tracks, Richo.
              Make sure sticer i laid flat, rub down across the APP tape with a squeegee or something fairly flat. this ensures the sticker sticks to the tape as it is medium tack.
              Peeling the backing off can "sometimes" be tricky if they have been sitting for a while. Persistence and patience is sometimes needed.
              Folding the backing away at a sharp angle is sometimes useful.
              Once applied, wettting the app tape will make it release from the sticker. Make sure to use firm pressure to apply it beforehand though!
              If the window/panel is wet to apply, you should leave it for a while to dry before removing the app tape.
                Cheers Piggy! I'll have another crack on the weekend. Paul
                [/SIZE]
                  Originally posted by Richoson View Post
                  Hi Rev
                  Hi Richo,
                  Like you, I can't wait for my 2012 GTG sticker! (Thats if SA has them.)
                  I was told today that my leave app for Sep / Oct 2012 has been approved.
                  So all I can say is BRING IT ON !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                  See you on the way to the 2012 GTG!
                  Lawrie
                    I'm sure this question has been asked a thousand times, but as a newbie to the forum, where on earth do you get these PP stickers from?
                    Roger
                    Toyota 150 DVD Silver Pearl, original towbar, Yokohama Geolandar ATS
                      Roger
                      At the bottom of the forum page in the marketplace section under Pradopoint merchandise, here's the link:
                      http://www.pradopoint.com/forumdispl...nt-merchandise.
                      Cheers, Brad
