After completing 15000 klms with a Waeco plugged in the inverter has blown twice. Does anybody have a solution as to be frank, Toyota have been not so good on advice.
Inverter blowing on a ZR prado.
Originally posted by wooley View PostRun it off 12volt like it was designed to be run?
Originally posted by Wandy View PostDoes anybody have a solution?
You don't say what model Waeco frig, but just checking the Technical Specs at the end of the Manual, says that a [CF-50] has a rated current draw of 7.0 amps, at 12 volts [84 watts consumption], and 0.7 amps at 240volts [168 watts consumption]. [Watts = Volts x Amps]
Now the manual does not explain if this is peak (starting) current, or running current etc, but it is possible that the inbuilt inverter is overloaded [168 watts] either way??* It is clear that it draining much less energy (about half) from the car when using the 12v supply, rather than the rear 240v accessories output.
There is also a power loss (wastage) in getting converting 12v DC to 240/220v AC, which makes it even less attractive.
As Andrew says, cut out the middleman, and run it directly from 12v.
bworth
* Couldn't find out rated output.Last edited by bworth; 01-01-2012, 01:13 AM.2006 120 Auto D4D, UHF, Toyota Alloy Bullbar, Towbar, 2xDIN Audio/GPS/Bluetooth Unit, Old SuperOscar HID spots, Stock standard body, suspension etc, pimped frig. [I]Wish List: [/I]Dual Battery, Roof Racks, Awning, Drawers.
