Out of balance
I've seen that before on a MT tyre. The sales person tried to claim that MT's always needed balancing like this. The bloke pushed the matter and it turns out it was a bad batch. They gave him a replacement set that balanced up fine.
MikeMy build [url]http://www.pradopoint.com/showthread.php?25816-Mikes-150VX-Yes-it-s-another-silver-Prado[/url]
It is the tyre, Cooper and BFG are having problems with their tyres ATM, as they will not ballance up properly, this has been happening now for the last 4 months, which is probably why BFG is hard to get ATM, they are waiting for them to sort it out.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by Jon View PostSo the point is, do not buy that tyre & rim, as the tyre is obviously faulty.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by croozza View PostThe rim would be perfect to buy, just the tyre is not.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by glen_ep View PostYou're making a huge asumption there, the rim could be out as well.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by croozza View PostWell, rims dont go out of balance, and it has no marks of damage on the rim.
I have run quite a few wheels without tyres on wheel balancers and they are always out a little, some quite a bit. Cheap aluminium wheels were always the worst, probably due to inconsistent casting. I guess the steel ones were out due to uneven welds.
There were some early HSV wheels that were cast so bad they were cracking due to large air bubbles in the wheel, which would put it way out of balance and just plain dangerous.
Originally posted by Auss15 View PostThats very old school and cheap balancing with bashed on lead weights to an alloy wheel. I would not have accepted it, you don't bang weights on to alloy wheels to balance them.
Decent tyre fitters only use self adhesive weights these day's so as not to damage alloy rims.
Judging by the amount of lead there, he had no choice but to fit the weights to the outside to get it to balance.
Some fitters also use the internal ballast although I'm personally not so keen on that system.Dave
Originally posted by Sako85 View PostYou can only do so much with those stick on weights.
