MDS I am biased on the subject of batteries. Despite the temperature under the bonnet I go for AGM batteries but there are many who don't agree. First you need higher charge voltage and second they are heavy. Mine is 40kg. And heat kills them. But I have a 120 Ah AGM and have used them now for 7 years. 75 Ah in a wet cell is low without supplementing charging with wind, solar or routine engine running. I camp with a 100 W solar panel and it keeps up with demand. Previously I had to run the engine every day and go for drives.
Wiring may be an issue too but running in the garage is much easier than in the car. Best check voltage at the fridge in the car with fridge running and then check battery voltage. Should be as close as possible. In my 90 I had to replace the fridge wiring after a couple of years because while fitting more bits and pieces I accidentally crimped the wiring and lost more than half the conductors. Same sort of issue as you and so I had the fridge serviced. Same problem and lo the voltage at the battery was 1 V lower than the battery.
I think you can get better fridges IF you can get a refund. Checking wiring is a sensible idea and a larger battery or solar panel as funds allow. Bear in mind my 120 Ah AGM is a 13" battery cost nearly $400 and I had to build a custom battery tray.
Good luck.
What connectors does the fridge have? If you are using Anderson power poles I can lend you a monitor to get the full story on your fridge consumption though you can buy them for about $60.
Michael
Good luck.
Michael
