since i mounted my air compressor in the engine bay, i ran an air hose to rthe rear of the car. However today the hose burst near the pump due to heat fatigue. Can anyone recommend a heat resistant air hose that would be suitable for use in the engine bay?
Advice wanted on heat resistant air compresso hose
My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.Tags: None
Went past Enzed today and picked up some hi temp braided cable. should fix the problem.My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
