Spotlight Wiring
This topic is closed.
  • Spotlight Wiring
    Hi All
    Can anyone tell me the correct connections on a relay to wire up my spotties as I was going to hook up to the Main beam curcuit but all 3 connections on the back of the headlamp switch are all giving me 12 volt readings with nothing switched on.
    Ive made a fused connection to Pin #30 direct from the battery. With a 10Amp fuse
    My spottie Negatives go to ground
    My spottie Positives go to pin # 87
    which leaves pin #85 ? and #86
    I,m assuming the main lights are positivly switched ?? so not sure on the other two connections
    Hope someone can help me out on this one
    Many Thanks
    Keith
    [i][b]Prado D4D GXL 2007 In Black[/b][/i]
    Hi Keith,
    The information you need is in one of these threads. ;-)
    http://www.google.com.au/search?hl=e...pradopoint.com
