my lift kit cost $1100 fitted in newcastle and im very impressed with the handling and load carrying, its an ironman heavy with low pressure gas shocks, my choice was price driven and im not complaining
what did ya lift kit cost and r u happy
I haven't lifted my prado yet, but out of curiosity what have people gone with in regards to stiffness front and rear.
I am tending towards heavy in the front with plan for a winch, dual batteries and compressor (already have the steel winch bar),
and medium in the rear with polyairs for articulation and load carrying.
Looking forward to reading price comparisons and combinations of setups.[B]Cheers
Bomber[/B]
'07 Silver Ash GXL D4D manual, 2" lift (Ridepro Bilstiens), Polyairs, Colour coded ARB Deluxe Winch bar, Safari Snorkel, Toyota Tow Bar, Sandgrabba Mats, Michelle's Sacs seat covers, Rhino Aero Bars, Rola Vortex Roof Rack, ARB dual Batteries, 40L Engel
about $400 for lovell springs and shocks/struts all round and im very happy
here is an updated pic of the rig
2004 GXL V6 5 speed auto. Cooper STTs, 40mm Lift, Scanguage II, Flyer batterybox, GME3400 UHF, Engel 40L, Safari Snorkel, IPF Xeon Headlight upgrade, Milford Cargo Barrier.
[img]http://users.on.net/matthewv/4wd/prado.jpg[/img]
lift cost
Hi all, Bilsteins shocks & lovell springs, love the ride and gives 50mm more clearance. $1960 fitted.
2004 3.0L TD GXL manual, Bilstein & Lovell springs 2inch lift, PolyAir Bags in rear, Piranha Dual Battery tray, Baintech Battery Isolator, Toyota Electronic Rust Protection, Sovereign Bull Bar
Would like to hear more, especially from Pradogxlv6 & KMKPrado.
Went to Preston on Sat / Sun just passed. Good estimate is that I had 180kg of gear in the boot (with cargo protector) and 100kg on the roof basket, evenly distributed. With no occupants, the rear was sagging by approx 3-4 cm, over normal. Drove with only driver and passenger up front.
Even with new Springs and shocks, would Polys also be the way to go? Any concerns with Polys?
I'm going to have a hard time convincing SWMBO that $2K is a necessasity just to get away with the boys.
Cheers.
P.S. Did have OME installed in a new Kia Sorrento.. piece of ^%&^ and sold it a year later. Was impresed with how the car performed after the fit.Mar 07 Prado D4D Auto GXL
Sovereign Bull Bar
Cargo Barrier
Rhino Roof Basket
Bilsteins / Lovells / Polys / 50mm Lift
AVN6000 Sat Nav / DVD / I-Pod / Rear Camera
i have heard pretty average reports from the bilstiens on the overlander forum.. not worth the extra $$$ imho.
id take the OME over the bilstien/lovel combo.. at the end of the day, they all perform much the same when it comes to articulation, ride does differ, but only with how they manufacture the spring rates. you will get a firmer ride if you upgrade to be able to carry more weight, so polyairs may be a better option if you arnt after the increase in clearance..2004 GXL V6 5 speed auto. Cooper STTs, 40mm Lift, Scanguage II, Flyer batterybox, GME3400 UHF, Engel 40L, Safari Snorkel, IPF Xeon Headlight upgrade, Milford Cargo Barrier.
suspension
I have had the prado loaded up with a 50L fridge, 3 adults, camper trailer, cargo drawers full of recovery gear, oztrail gazebo on top and soft gear in rear and only very little sag compared to standard which use to look like a space launch to the moon. I read mention of an overlander review on Bilsteins, if it is the same one that I read in a edition from last year they rated Bilsteins in the top three second to Edelbrocks, not bad in my book. I have read several reviews on Bilsteins and all rated them very well. I have no experience with OME so can't comment or compare but I am very happy with ride height, cornering, and handling with the new set up and would recommend it to anyone considering a change. It would be my first modification on the next one. My 2 Cents.2004 3.0L TD GXL manual, Bilstein & Lovell springs 2inch lift, PolyAir Bags in rear, Piranha Dual Battery tray, Baintech Battery Isolator, Toyota Electronic Rust Protection, Sovereign Bull Bar
Originally posted by Up The CreekEven with new Springs and shocks, would Polys also be the way to go? Any concerns with Polys?
Unladen the rear sits noticeable higher than the front giving a nice rear to front angle. Package performs great unladen. I will be adding Polyairs in the new year.
Cheers - Byrnsie
lift cost
I found a review on suspension packages that may help those still making up their minds. It is in the 4x4 Australia Gear Guide No. 4
They tested OME, Edelbrock, Raw, Bilstein, TJM, Ironman & Tough Dog shocks and spring setups. I have paraphrased a couple below.
Bilstein & King springs combo:
'The laboratory testing confirmed what we've known for some years: Bilsteins are great performance shocks.'
'Testing revealed that the shock absorber's bump and rebound damping was strong at all velocities.'
'The ride quality of the Bilsteins was judged to be slightly firmer than the other monotube shock tested, the Edelbrock/King set-up, but was still very good.'
'Axle control was excellent on all surfaces and overall vehicle handling was judged safe and predictable.'
ARB Old Man Emu Spings & Nitro chargers shocks combo:
'The testing showed the shockers had very little bump (compression) damping at low velocities and this amount reduced considerably when the shockers were hot.'
'Front rebound damping was also on the low side and, while they had more, the reats lost a proportion when hot.'
'On-road the ARB springs produced the equal best ride, with king springs, but damping was judged on teh soft side. There was a 'pattering' axle movement on small bumps and larger bumps and potholes resulted in some sideways axle movement.'2004 3.0L TD GXL manual, Bilstein & Lovell springs 2inch lift, PolyAir Bags in rear, Piranha Dual Battery tray, Baintech Battery Isolator, Toyota Electronic Rust Protection, Sovereign Bull Bar
Newbie question...
With owners investing almost $2K on shocks/springs/polyair, is this something that you would remove when you sell the vehicle, assuming you could put it into the next Prado?
Just wondering if the investment lasts a lifetime of Prados, or if it's per-Prado.
Thanks,
LFaR.[size=1][color=#770000]29Feb12:[/color][color=#777700]12GXLTD Auto, ARB Deluxe Winch bar, WARN 9.5xp Winch, IPF 900XS, Tow, Safari snorkel, Front + Rear Recovery points, ARB OME NC Sports, ATZ-4Rib[/color][color=grey], Silver[/color]. [color=orange][b]MaxTrax[/b][/color], [color=maroon]ScanGuage II[/color], [color=blue]ARB CKMA12[/color], [color=deeppink]UHF: GME TX3440 AE4018K1 UNH047SX[/color], [color=darkgreen]Bushranger Air Jack[/color], [color=green]Staun + ARB Deflators[/color], [color=brown]WindCheetah Roof Rack[/color], [color=green]Foxwing[/color], [color=red]Super Charge MRV70, Redarc BCDC1220[/color], [color=darkblue]ARB 60L fridge[/color], [color=blue]MSA Fridge Dropdown slide[/color], [color=darkyellow]DRIFTA Drawers[/color], [color=gold]TJM Bash Plates[/color], [color=brown]TG150[/color].[/size]
lift and cost
personally I will leave it on this vehicle and redue when the time comes on a new one since I didn't keep the stock suspension. Probably should have kept them but I am not mechanically wise so I couldn't replace them myself anyway, others likely would.2004 3.0L TD GXL manual, Bilstein & Lovell springs 2inch lift, PolyAir Bags in rear, Piranha Dual Battery tray, Baintech Battery Isolator, Toyota Electronic Rust Protection, Sovereign Bull Bar
