Hi Guys
Got a strange issue with my lights that I have never seen before and hoping someone might be able to help.
I got a HID kit from Jaycar, the length of wire between the globes and ballast was not long enough so I extended it using some more wire, the wire I used is larger than the wire in the original kit so I thought it would be fine.
Now when I turn the highbeams on to get spotties sometimes the HID's do not fire up, approx 50% of time. When they don't fire I get a buzzing sound at the joint closest to the ballast where I extended the wires. I soldered the joints.
I have a relay to switch them on like any normal spotties and to narrow down lack of power as son googling suggested might be the case, I tried running power direct to the ballast from battery as a test, I got the same outcome. Both lights do the same thing.
So I was wondering if anyone has had a similar issue or if any of the knowledgeable folks out there might have any suggestions?
