200 series won't start
  • 200 series won't start
    Hi all I know it's not a Prado but sure there are people on here with one and I give up trying to use lcool worst bloody website to log into. Anyway it's for my wife's boss his 200 is stranded at cooma as the water trap light come on so he pulled over undid the trap thingy under the fuel filter, jumped back in and won't start just turns over. He filled it up in Sydney prior to leaving to drive to cooma. It's turbo diesel.... Cheers Steve
    I'm certainly no expert but sounds like air has got in the fuel system?. Again I'm no expert though.
    Steve
    2000 Grande
    Toyota Alloy Bar, IPF 900XS, 50 mm Lovell Springs in rear, Safari Snorkel, Kaiser Roofrack, Milford Cargo Barrier, Hercules AT's, Blue tongue compressor, Uniden UHF, Dual Batteries, Home made rear drawers, 45l Waeco with Waeco temp monitor, Side & rear awnings
      Don't the water traps have a little manual primer pump on them?? if so give it a bunch of pumps to prime the system perhaps.
        First off how much water, if there was a lot then your going to have to
        drain the tank and flush the system, if water has gotten into the common
        rail you have problems.
        If there was a only a small amount, drain water make sure drain is closed then prime the system using the primer pump on the fuel filter, keep pressing till the button goes hard.
        Leigh
          He said buggar all come out of the bowl. But he said he didn't pump/prime it up just turned the key. He said he read the book and nothing in there about priming so he didn't do it. He's back here in Sydney at the moment and the cruiser went to a local work shop in cooma. He stopped the vehicle the moment the light come on for the water trap. He was wondering was it due to condensation in the tank ?? Was -1 the night before. His insurance told him he should have used alpine diesel. Told him gets -1 here some times in Penrith and we don't have it here.... Cheers Steve
            Alpine diesel , your not really going to need around cooma , and shouldn't have anything to do with water in your filters . Some Diesel engines do self prime , you will have to RTFM or take it to a mechanic . This guy should RTFM ! If the car was running fine b4 he drained the water off and now doesn't run then its a good chance it needs to be primed .
              Isn't alpine diesel only needed when it's actually cold? We get down into negative temperatures at home and regular diesel's just fine?
              Oh and yeah, I'd suggest priming it.
              2011 150series GXL
                water in diesel could have filled the filter and not self priming as not enough fuel is passing through filter. change it and prime it. 200 series turbo diesel in mongolia is notorious for its poor injectors. so have it checked by the mechanic.
                  Just a follow up, turned out to be the filter, they replaced fuel filter primed her up and fired up straight away. They haven't said anything about draining tank but he is going to then replace filter again when he gets it back home here in Sydney....cheers Steve
                    Good result , he caught it early , if you were outback and without a spare filter , just empty it out and go again . Cheers
                      good to hear it's now ok, we have horrible diesel in mongolia. if the filter is stuffed and temp drops to minus, water in the filter will freeze and total lack of fuel in engine, so normal seasonal service always include flushing the bank and change of filter. all this is not a good news for injector.
                        Yeah gantulga, he was pretty happy with the outcome to say the least. He is still going to drain the long range tank just to be sure then apply new filter again. He was picking back up again today from Cooma...... Cheers Steve
