Tyredog TPMS
  • Tyredog TPMS
    Have installed a Tyredog tyre pressure monitoring system. Works well.
    However find it readings a bit disconcerting. Following discussion I tyre pressures decided that I would use 36psi around town. Went to local garage and set pressure. TPMS however - without driving anywhere - shows 2 tyres at 36psi 1 at 38 and 1 at 33.
    Is this a Tyredog monitoring problem or the pump I used?
    Terry
    Canberra
    Terry
    Get yourself a tyre gauge and test with that. You'll still need one as a back-up for the TPMS anyway so buy a decent one.
    Trev
    Check out our around Aus adventure on FB at: Cummings and
    Goings
      Welcome to the world of too much information and being OCD about getting all the pressures matching. Don't worry it will wear off after a week or so.
        OGF use the Tyredogs as a guide only. Get a decent tyre pressure gauge and use that whether you fill up at a service station or your own compressor. Learn the variation that your Tyredogs display.
          Thanks - I have two very good tyre gauges - just haven't used them yet.
          Will check them out.
          Terry
          Canberra
            Tyredog problem as sensors are not accurate enough, they seem to provide more of a guide as to when something is changing
            Live One Day at a Time for Tomorrow May Never Come
            Build Up: [url]http://www.pradopoint.com/showthread.php?15022-FC-s-120-D4D-GXL[/url]
            Toyota Prado D4D-SOLD; now a 2014 Landcruiser 200 Altitude, Holden Colorado DCab [url=http://www.fuelly.com/driver/effiec/colorado][img]http://www.fuelly.com/smallsig-metric/48073.png[/img][/url]
              Hey Oldgreyfart do you have the internal sensors or external ?
              Cheers Ross
                Amen to that brother.
                  Cheers Ross
                  Tyre dogs have the external sensors. Mine are fairly accurate but I really only use them as a guide, I still use a gauge to check pressures.
                  The one thing you will learn is just how much tyre pressures can vary depending on ambient temperature and heat from driving, it's a lot more than most people might suspect.
                    You they're a guide only as they have a +/- 0.5 PSI accuracy.
                      Mine's pretty accurate to ±0.5psi on both sets that I have.
                        External.
                        Cheers Ross
                        Terry
                        Canberra
                          Tyre monitor would've stopped me ruining a Cooper AT3 recently due to low pressure I suspect . A guy on the trip had the ext sensor type and I reckon it's a bloody hassle having to undo the tiny allen screw to take the sensor off when a pressure change is required . I'd only go with the internal sensor .
                          Cheers Ross
                            Unless you don't do the tamper proof thing in which case they just unscrew like a normal valve cap. I have both systems on different vehicles and they both have advantages and disadvantages. The external sensors work fine for my purposes.
                              I'm presently not using the tamper proof locks and as mjr stated, they just unscrew like a normal valve. I guess you could install the tamper proof locks for day to day driving and then remove them prior to going off road for quicker inflation/deflation times.
