Have installed a Tyredog tyre pressure monitoring system. Works well.
However find it readings a bit disconcerting. Following discussion I tyre pressures decided that I would use 36psi around town. Went to local garage and set pressure. TPMS however - without driving anywhere - shows 2 tyres at 36psi 1 at 38 and 1 at 33.
Is this a Tyredog monitoring problem or the pump I used?
