Hi all im in need of some expertise...i will admit right now that my electrical knowledge (amps/volts/watts etc) is very limited.
My compressor packed up the other day. The in line fuse melted and took the fuse housing with it. The compressor is a portable one and worked very well up until then so im hoping i can fix/upgrade it.
The max amperage on the compressor says 45 amps however the fuse in the housing was a 30 amp fuse(it came like that)? What does this mean? was the fuse too weak?it always used to get very hot when the compressor was going and if i ran it for too long it started to melt...... The cabling also looks a bit cheap/weak so im not sure if its up to the job of transferring the current. The cables attach to the battery via crocodile clips. I was thinking i could get a new cable length and in line fuse holder more up to the task. Would this work? Or should i just change the in line fuse holder and then use a 45amp fuse (if they exist?)?
Or do i need to keep the 30 amp fuse as anything more would damage the compressor? Help i have no idea about this stuff!:shock: but i dont want to chuck away a perfectly good compressor for the sake of a $5 fuse holder...
Some other specs that might help...(printed on the compressor)
voltage 12 volts
max pressure 150 psi
max duty cycle @ 72 degrees Fahrenheit and 40 psi 30 mins
max air flow 150 litres per minute
its an outbac brand one
Thanks in advance
voltage 12 volts
Thanks in advance
