So you reckon you can change a tyre?
2008 D4D M6 GXL [MT ATZ-P3][Whitey's Ironman 45710FE/45682FE+KTFR101H/Dob487][extended Roadsafe links][Polyairs][DBA T3/T2][amts diffdrop & recovery points][Tin175's stone guards][Bushskins BashPlate][ARB Sahara][IPF 900s][Snorkel][WindCheetah][MaxTrax][IC-440][Parrot Asteroid][ARB Fridge][Lifestyle 2nd Row Fridge Mount][ARB Compressor][Thumper][SandGrabbers][Cargo Barrier][Tigerz Awning][MCC Rear Bar]Tags: None
What will they think of next? Oil change.Dave
Now that is pretty spectacular. Makes stunt artists from the western world look like beginners - although life expectancies would differ somewhat.
Now, technically, that's certainly not standard drive line behaviour... any thoughts on how that was possible?glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by glen_ep View Postany thoughts on how that was possible?
Notice they only had 2 wheel nuts per wheel?
No Saudis were harmed in the making of this video, though plenty were killed in the practice run...Silver '04 KZJ120~Manual~GXL~Dobinson/Kings lift~Custom valved Ironmans~Detroit Locker~Endless Air~X9 Superwinch~Madman EMS1~TJM Dual Battery~Rhino Roof Tray~120W solar panel~Foxwing awning~Bushskinz UVP~Long Ranger water tank~Bushman fridge~Steinbauer P-Box~Beaudesert 2 3/4"~Airtec Snorkel~TJM Sliders~Prico Boost Gauge~BFG-KO2s~TPMS~GME TX3420~Front and Rear Cameras~Ultimate Camper hanging off the back!
Well lockers would cause the raised tyres to spin, so unless there's missing axles, that can't be it.
The lifted front wheel spun in the air initially, and whilst wrenching, so I'd say the entire front prop shaft is removed.
The lifted rear stopped spinning the moment it lifted, and never moved whilst wrenching, so I'd say they have an independently controlled brake on that, and an open rear diff.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Way too much time on their hands, time to get a real jobWhy are my tires only wearing on the outside shoulder Dad?
Originally posted by amts View PostThe FJ can be driven in 2wd mode.
FJ sounds like a pretty good vehicle - 2wd and large flares for fitting 33's easilyglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by amts View PostYes, and rear diff lock and CRAWL control is standard along with dual tanks now.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
I'd still rather get through with my own throttle control and lockers (which I need anyway for the terrain I usually drive)
Too much computers = boringglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
