Hi guys, I tried a search, but the search results either said " too short " a word to search, or " no posts matching"
I'm running 2 x AGM optima batteries, and the Fuse that ups the alternator voltage ( off the fellow PP member ) but I find my rear light which is an led starts to flicker after a day.. I could be wrong, but to me it seems that the voltage drops off after a day or so..
Every month or so, I connect up a CTEK battery charger, and give it 3-4 days constant charge.
I've just learnt ( you tube ) about the red arc DC-BC charger and thought I might give it a go! Has anyone else got a similar setup, or are you using a DC-BC charger?
