D Shackle rules
I know NSW any new trailer or interstate rego transfer has to have rated safety chains. First I have heard about shackles.
Sent from my SM-P900 using Tapatalk2013 [COLOR="#006699"][B][SIZE=2]Blue Storm[/SIZE][/B][/COLOR] D4D 150 GXL Auto, Opposite Lock Bullbar, Safari Snorkel, GME 3345 UHF + AE4018 Antenna, HR Tow Bar, TG150, HD Rhino Roof Racks, Foxwing, Dual Batteries, C-Tek DCDC Charger, ARB 47L Fridge, ScanGauge II, Internal Fishing Rod Storage, X-Ray Vision HIDs and LEDs, New PP Sticker.... [COLOR="#808080"][SIZE=1][/SIZE][/COLOR]
I noticed that many late model cars with tow bars come with rated shackles. On a side note, during recent AUSTRANS operations here in Broome and Kununurra they found 1 in 4 caravans with break-away breaking systems didn't work. That would certainly put value in having proper rated shackles.Last edited by Bushbasher; 23-12-2014, 08:23 PM.Dave
Having a WLL on shackles has been law for quite some time. I haven't checked but presumably the ADRs or Codes of Practice specify a load rating required based on trailer capacity. First I have heard of anyone being fined though. Mine are HR branded so I need to check if they are stamped with a load rating.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by jonoxplor View PostSmall difference, the shackles pictures are bow shackles, D shackles are well, D shaped!
When using straps for example, the strap should sit in the Bow of the shackle, and NOT against the pin!
Obviously ARB has it all wrong, someone should let them know.
Originally posted by BrettM View PostMost of them do it that way AJ, all I'm saying is from a rigging point of view it's incorrect
The ARB points are probably the only recovery points on the market that would come within a bulls roar of the standards for rigging, and as I said they are designed to have the shackle the other way round.
Anyway that's all getting way off topic, I've had rated shackles on my towbar for years so new laws have no effect on me.
May be simplistic but I would have thought the strap on the pin would be best. It would give even stresses right across the width of the straps eye where as the other way puts more stress on the outer edges of the strap. Also the shackle in the recovery point hangs naturally in its neutral position and shouldnt slide under stress which a flat surface will probably do.
Ian2014 VX D4D. Dobinson 2 inch lift. TJM T3 Bullbar. rhino platform. TraxRax. Maxtrax. Dual batteries. GME TX3450.
I found some interesting info on shackles tonight. I had a look at the NTs rules as I'm moving up there next year. Turns out you must have rated shackles up there and it has been that for 4 years.
http://www.transport.nt.gov.au/__dat...s-Jan-2013.pdf
Originally posted by Ian Reid View PostMay be simplistic but I would have thought the strap on the pin would be best. It would give even stresses right across the width of the straps eye where as the other way puts more stress on the outer edges of the strap. Also the shackle in the recovery point hangs naturally in its neutral position and shouldnt slide under stress which a flat surface will probably do.
Ian
A point load should only ever be on the pin if it can be centred and kept there. It doesnt happen in recoveries.
If you had the strap in the bow it bunches and pulls on the edges first, edge loads reduce overall load rating of straps. If the pin is through the recovery point it then is almost certain to slip to the edge of the pin, therefor taking the overall load axis off centre reducing the load rating of not only the strap but the shackle itself.
ARB is right in application AJ120
Yes that's correct about the load being central on the pin. Another thing is that a shackle shouldn't really be use for snatching as they should never be shock loaded, the WLL on a shackle is rated for lifting. We could go on and on about it and in the end we will all still use shackles for recoveries
According to Camper Trailer Touring Facebook page, QLD Transport "recommends" rated shackles. Not mandatory apparently. I remember when I got my camper changed over to WA rego from QLD I had to change the chains and shackles to rated ones. That was about 4 years ago.Can't we just keep travelling?
Travelling Panelbeater
