I've also just purchased a 120 prado and the seller didn't supply the key for the wheel cover. I found that with some pressure on both sides of the cover down low it would come loose enough to slide off the bottom and then I can still lift it off then. I was also lucky the the lock is also missing for the nut on the spare wheel holder.
I found on eBay a replacement lock for the cover if I can figure out how to get the old one out and a lock for the nut.
http://m.ebay.com.au/itm/281480224834?nav=SEARCH
http://m.ebay.com.au/itm/271554438084?nav=SEARCH
